February 13, 20188 yr comment_474499 Hi all, What type of vans do you use and do you find them reliable? Leased or owned? Most co's seem to use Berlingos or something French up here in Scotland. I assume cause they are cheap to run? Grant Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 13, 20188 yr comment_474501 Dispatch swb Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474501 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 13, 20188 yr comment_474505 Transit Connects mostly, we also have a Traffic, a kangoo and a Vito. We own them all, and two connects are due for replacement this year as theyve done starship mileage Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474505 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 13, 20188 yr Author comment_474507 How have you found the Traffic Peter? Heard horror stories of gearbox issues on nearly new vans, perhaps they've sorted them out? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474507 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 13, 20188 yr comment_474508 Say you want a mid sized van.. You can buy Renault with a Renault engine or a Nissan with a Renault engine or a Vauxhall with a Renault engine or a Fiat with a Renault engine or a Mercedes with a Renault engine If you not keen on Renault... There's a Peugeot, Citroen, Fiat, Toyota & a Ford with PSA engines If you don't really don't want french, either do your homework or go VW ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474508 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 13, 20188 yr comment_474511 31 minutes ago, grantc said: How have you found the Traffic Peter? Heard horror stories of gearbox issues on nearly new vans, perhaps they've sorted them out? So far no problem ours is restricted so dont know if that makes a difference, the kangoo on the other hand has had a new box, and that new box has been repaired again under warranty Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474511 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 14, 20188 yr comment_474542 11 hours ago, MrHappy said: Say you want a mid sized van.. You can buy Renault with a Renault engine or a Nissan with a Renault engine or a Vauxhall with a Renault engine or a Fiat with a Renault engine or a Mercedes with a Renault engine If you not keen on Renault... There's a Peugeot, Citroen, Fiat, Toyota & a Ford with PSA engines If you don't really don't want french, either do your homework or go VW ? Lol, that’s right! the only one that is surprising is merc borrowing a Renault engine! Vivaro traffic primastar do have gearboxes supplies by Thornton’s apparently..... I’ve had 3 and never had an issue, they do get bad clutch judder sometimes when pulling away and that’s from brand new! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474542 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 14, 20188 yr comment_474545 28 minutes ago, sjsturner said: Lol, that’s right! the only one that is surprising is merc borrowing a Renault engine! Vivaro traffic primastar do have gearboxes supplies by Thornton’s apparently..... I’ve had 3 and never had an issue, they do get bad clutch judder sometimes when pulling away and that’s from brand new! It's actually Renault-nissan for the mercs I think, on entry level cars , higher supposed to still have the Merc engine Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474545 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 14, 20188 yr comment_474562 I've got a 15 plate Traffic, had several warranty jobs so far.... Broken down several times with dodgy electrics, used to turn its headlights on when left sometimes! Was leaking oil and now has a fault on the steering wheel, clicks like crazy sometimes, garage won't fix it as it doesn't do it all the time! 85k miles now. I would never spend my own money on such a **** vehicle! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474562 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 14, 20188 yr comment_474563 VW SWB Transporter 100ps. Very nice van but only average 33 mpg. Due to adblue the diesel tank is 15 litres smaller so only do 350/380 out of a tank. Nearly 1.5 years old and only put 15k on it from new. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41948-vans/#findComment-474563 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
