Texecom speech and text Dialler , Text not working
Thank you for your reply.
I bought this from Ebay and the below description it had and the Texecom speech Dialler sold as new.
I have attached the image which was advertised and on the description it said it does voice and text.
on the box it says CGA-0001-REV 3.So does this mean I got ripped off , as it only speech Dialler and no text message .
what is TAP ?
How do go about using Sms Max
And using outputs and connecting to a gsm dialler, where would this be connected.
Ebay item description as below
Speech Dialler
32 character LCD display
4 trigger inputs, 4 voice messages, 4 text messages
Dials 8 contact numbers and incorporates 2 programmable outputs
Call abort, listen in mode, talkback mode, memo feature, context sensitive help, passcode protection
Remote access plus upload/ download via Wintex software
  • Replies 53
  • Views 17.1k
  • being our resident texecom nerd....   How old do you reckon that  cheapest made in china  "awarding winning technology" battery is ?
  • little soot marks around the endstation ?
wow someone bought something off ebay and its not doing what you thought? send it back
The first one he sent it was faulty and I returned it back and he said he will return it back to the supplier. This  is the 2nd one he sent ,so this one may be speech Dialler only then , without text sms message.
However there is also text option on this 2nd Dialler as well for sending text messages , but this function will not work on this model texecom Dialler , as it has no text function , even though it shows on the unit for programming for text sms.
I agree you bought a Speech Dialler as described. The manuals and menus are the same on both models.
TAP is pretty unreliable anyway so I wouldn't worry about it.
This is the current one he is selling right now, which speech only, the one I bought had the below description and I thought I was buying speech and text Dialler going from the description below
Speech Dialler
See attached pictures described by the user , so did I buy Speech Dialler only or speech/Text Dialler?
