Work extension and tech upgrade
Pics? I'm not falling for that you know:lol:
It's a heavy duty steel security door from these guys: https://www.lathamssteeldoors.co.uk/ (maybe you know them?)
  • Replies 93
  • Views 17.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • he'll have the linksys type
  • sixwheeledbeast
    sixwheeledbeast
    Honda and Rossi will always have opposite agendas since they parted.  2015 was an interesting season several debatable events right through the season, the back of the grid penalty at the last ra
  • Reminds me of the old sketch done by Harry Enfield, with the two geezers down the pub talking about Nigel Mansell speeding
Posted Images
but there's always a trap,
doors appear to be made to no recognised standard, apart for the option of a kitemarked euro cylinder ?
sort of thing often found on a porta unit...
your mag lock will reduce the head of the door & should be in transom
if you've not purchased the door & frame, an alloy door with a sash lock & deadlock factory fitted would be my preference
Starting to get that after, what, 12 years?:lol:
Didn't think of that, thank you, I'm 6'3" so will look at that carefully.  If it didn't interfere with the shoot bolt system, it could maybe go at the top of the jamb...
Door is all installed BTW.
a yale / cisa latch (you will need to fit the lock cylinder if its  he only entrance) or a surface solenoid bolt
is what I probably look to do.
Fail secure door release jobby? Keep it simple
  • 2 months later...
Fellas, can you confirm that the armature fixing bolt needs to go all the way through the door leaf and out the other side? Logically with the pulling forces involved I guess it must do but I never considered having a bolt head on the external side so it seems odd.  On the other hand I cant imagine sourcing an 8mm self cutting screw and holding it on with that.
Straight through to next door
Sometimes when I come here and ask questions, it reminds me of being at work.
It's like pulling teeth.
I'm here all week, the veal is reconstituted from Norway.
should go all the way through, should be a 'coach' type bolt so cant easily be removed. If thats a risk use a different type of lock
