October 10, 20178 yr Author comment_469549 9 minutes ago, MrHappy said: If the gap is too wide the reed may not close / may open after a period of being set Depending on the case design you mage be able to double up the magnets which give them more "pull" I could probably piggy-back the magnets and use long screws. I would prefer to keep the contacts off the chamfer if possible, plus the wiring would have to be stretched (mightn't be possible) , plus holes where the contacts were, left visible in the window. About 22 pairs are like this. Edited October 10, 20178 yr by Eugene's DIY Den Talking Tools, a Facebook group for discussing anything tool/DIY related. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-469549 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 10, 20178 yr comment_469556 3 hours ago, Eugene's DIY Den said: I could probably piggy-back the magnets and use long screws. I would prefer to keep the contacts off the chamfer if possible, plus the wiring would have to be stretched (mightn't be possible) , plus holes where the contacts were, left visible in the window. About 22 pairs are like this. Looking at that frame it's messed up, you could drill in and out from the chamfer if your going enough If you ever remove the contacts which I doubt you can always have all the upvc repaired these days but if it's your windows you can do as you need to www.upvcdoctor.co.uk They normally charge for a set of windows in the big scheme of things it's cheaper than trying replace or bodge it yourself Or similar companies that was an example Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-469556 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 15, 20178 yr Author comment_472319 Replaced all the contacts two months ago in the same position. Haven't had any issues with false alarms. Talking Tools, a Facebook group for discussing anything tool/DIY related. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-472319 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 15, 20178 yr comment_472320 Going to back to what H said earlier, didn't Ade, or maybe the Knight's chap, once imply that reeds are no longer made in the UK and the 2 qualities are basically 'USA or China' with nothing inbetween, as it were? I think he also said that often quantities needed dictated ordering from both areas more often than not, so there is no easy way of knowing where your reed came from in your otherwise 'UK made' contact. I have had loads of failures, usually stuck closed, with those Ventcroft 'Premium' contacts, I don't use them any more, shame as they are a nice looking surface contact with easy EoL and a decent tamper spring. I use Knights for surface inc. industrial and RSD etc... and Elmdene circular Quickfits for flush. Edited December 15, 20178 yr by datadiffusion So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-472320 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 15, 20178 yr comment_472322 I know one company in the South East who makes reeds that are used in the alarm trade Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-472322 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 15, 20178 yr comment_472323 Fair enough then! So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-472323 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 15, 20178 yr comment_472324 53 minutes ago, magpye said: I know one company in the South East who makes reeds that are used in the alarm trade Great for brexit Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-472324 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 15, 20178 yr comment_472325 15 minutes ago, al-yeti said: Great for brexit & also brentry ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-472325 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 15, 20178 yr comment_472327 49 minutes ago, MrHappy said: & also brentry ? New regs yeah? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-472327 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 30, 20197 yr Author comment_486935 After over a year and a half since I posted this, several more contacts have stuck (on windows that are never opened). Talking Tools, a Facebook group for discussing anything tool/DIY related. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41635-magnetic-contacts-sticking-on-un-opened-windows/page/2/#findComment-486935 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
