hard wired pir fault ?
3 hours ago, norman said:
Is that PCB in the case upside down?
No I don't think so, and I think it is the micro x line from looking at PDF online.
  • Replies 35
  • Views 8.7k
  • im still sticking with electronics line micro X (maybe early version)
  • Muttsnutts
    Muttsnutts
    No there is no lid fixing screw ! There is a special tool to release cover ifs against celing, like one in pic ....
  • sixwheeledbeast
    sixwheeledbeast
    I'd guess aesthetics, smooth lines on the bottom of the PIR. In reality some numpty engineer turns up and puts screwdriver rash all over it.
How do you get the screw in when it's adjacent the ceiling?
Remove the small screw on the pcb and pull board away and fix the the rear of the housing to the surface and re attatch
So you know the model all sorted
Yep cheers all for the help.
7 hours ago, Muttsnutts said:
looks a pile of poop...
replace with an dt8016 or an Iwise DT,
the toolstation pir is tat
No, the casing screw (hole) shown @ the top of the photo.
Edited by norman
Umm it's the small phillips one just to the left of the red led ?
no the lid screw, not the pcb screw
You Deffo have to remove the small pcb screw to fit it to a wall.
Installation Instructions
1. Open the housing by removing the front cover. To do so, press the tab located on top of the detector.
2. Remove the PCB by unscrewing the PCB screw from the rear of the protective plastic casing. Note: Do not touch the face of the PYRO sensor.
