hard wired pir fault ?
Need some help if anyone is in the know. Just in the progress of moving alarm pir sensor and when connected it's now setting the alarm off, tamper circuit is ok. When the sensor is disconnect the system is fine. Only have one pir on the system and one door connector. I'm not sure if to do with these "jumpers" in the pir sensor is causing the problem. Not sure what they do or how they were connected, one is labeled memory and the other p count. Can anyone shed light on what jumper goes where ? And if they cover two wires horizontally or vertically ? TIA.
  • Replies 35
  • Views 8k
  • im still sticking with electronics line micro X (maybe early version)
  • Muttsnutts
    Muttsnutts
    No there is no lid fixing screw ! There is a special tool to release cover ifs against celing, like one in pic ....
  • sixwheeledbeast
    sixwheeledbeast
    I'd guess aesthetics, smooth lines on the bottom of the PIR. In reality some numpty engineer turns up and puts screwdriver rash all over it.
looks right old.,...
pulse count, no. of pulse of movement before the alarm relay opens
memory - I assume a latch indication if multi sensors where on one circuit
it looks proper old?
Terminals look c&k, also the rheostat top left for the mw
it looks a bit like an electronic line  Micro X
(Dual Tec) - but I cannot see the microwave part of the sensor
Edited by aissecur
Additional info
Looks like it's @ the back
id say its a pir with a range pot
but id say vertical in answer to the OP
looks old and it looks a bit oxidised too, what state is the cable in? Link the tamper circuit at the detector end (dont used the detector terminals twist the wires together)
