EURO46 woes....
It was probably the reading from the ACT...
  • Replies 28
  • Views 6.7k
1 hour ago, POC said:
Ok, update.
I put in the engineer code (no on screen confirmation that i was actually in eng mode?)
Removed cover, no alarm.  I was met with this mess (see pic).
Upon pulling off the negative battery wire the alarm sounded saying 'control panel tamper, restore required'
Now what?  Anyone know of someone local to Hemel Hempstead that can fix this?
thanks, Paul
Almost as good as my wiring
They all look neat with the lid on...
once you get it on..
Yes man
I stopped buying the spring loaded 8core so lid doesn't pop off if you loose clips or screws , tape holds it on
Preferably brown parcel type for quality
new battery installed today, all problems instantly disappeared!
FYI date stamp on te old battery was 09/2012 and it was hot to hold when removing it tonight.
Edited by POC
8 minutes ago, POC said:
Thanks for all the advice, very friendly and helpful   B))
ty for the feedback
