Elmdene bell box wiring help
I have just got a new Modern Security Systems bell box, made by Elmdene, dated 1992, however when power is applied, both sirens will sound very quietly, not at full power t all. Is this a problem with the bell box, or the wiring? I just put 12V into the Hold Off and it started sounding very quietly. Does anyone know if this has SAB/SCB functionality, or is it just SAB? If it is SCB, i know that it is the batteries that are the problem, I just need to change it back to SAB somehow, if this is the case.
Thanks In Advance :)
  • Replies 22
  • Views 8.9k
  • Well, I go out with my friends, don't worry... I'm not THAT sad  I tried all of that, but it didn't really work. Do you have any idea where I could get a Eurobell module? That is my next hope
Could be the batteries dragging it down, but I'd take the engineer link out first and try again.
looking the pcb it don't look the best
I tried that, and it made no difference. I'll try removing the batteries and try it again. It's a nice bell box, shame Modern are no longer around. What does the Engineer link do?
I know, that was my concern, it may be damaged beyond repair. I'll have a go at removing the batteries and try it again
If you're just putting power on are you holding the tamper switches down as from memory the things sounded when you put power on till the tamper switches are closed, also watch the big white paddles as they were for anti foam and caused nothing but hassle so slide them off
Trade Member
Rear tamper switch looks goosed to me.
Well, I am trying to hold them down, but it wont stop, I am n ot really bothered about any of that working, all I want is it to sound at full volume when power is applied
Yeah, they are are... Sadly. Do you think to get the volume of it up, I could use something like this: http://www.ebay.co.uk/itm/LM386-Super-Mini-Amplifier-Board-Module-3V-12V-Kit-Red-Led-Light-Blue-PC-Board/252628203210?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44779%26meid%3D597b9836e54d40ae8cef13a9609a3762%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D332261893488 I am thinking of it.
I removed them... no difference :(
shouldn't a young man like you be drinking cider or sniffing glue in the park ?
its old tat but try-
close the 3 tamper switches - bolt, bottom & back
leave the 2 anti foam switches open
add hold off voltage, with tampers close it should be silent
if so, wire link from rtn to & it should ring ?
Nah, the kids these days prefer to be sniffing cider and drinking glue.
they'll come unstuck...
