Why Wi-Fi and why Battery Bell/Sounder ????
39 minutes ago, skronk said:
And would I be entitled to relevant codes from installer ???????
No, I certainly wouldn't provide codes for a system that had a warranty.
You could have them service it and reset the code when the warranty expires.
  • Replies 45
  • Views 8.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Many yrs ago I did a job in Ardrossan.   Its made Mablethorpe look like Las Vegas...
If you have the code some may not warrant it.
Maybe worded wrong !
Can I get the codes once the years warranty is up ?
Playtime !
Any decent installer would not allow engineer access etc during warranty or service period imho. There would be a charge to call out and reset the installer code at the end of that period etc
Question from wifey.......she does come up with good ones sometime !
If I buy the box from a supplier. Not installed. I own the box. How do I get the codes then, or do I just pay my cash and whistle ?
Edited by skronk
that's a diy install and you can do what you like
Both Engineers and User codes will be the default values and your responsibility to change them.
If someone installs a system they will provide you with a user code but keep the engineers code so only the installer can make changes.
depends wether you want a pro service provider, fitter or diy really
James,
What I am simply asking is...
1. Professional install. Can I get this mystical code once my 1 year warranty is up ?
2. Should this be DIY install, is this mystical code inside box, if not where is it ?
Obviously only masonic based people make these boxes as everythings a secret !!!!
Hard work.
Just now, skronk said:
James,
Hard work.
1. Yes but the provider cant give you the code as it may be in multiple systems. Would you want a security system provider that didn't care about protecting their clients. They will have to attend and change it and this would be a chargable call.
2. If diy then then default codes will be supplied
