June 3, 20179 yr comment_463600 Hi All, Just looking for a bit of advice. We have been using the Hik-Vision stuff for a while, but due to the current issues with the new Hik we decided to try out the Dahua HDCVI stuff. I installed a DHI-XVR5104HS with some DH-HAC-HDW2401EMP cameras. The problem I am having is when I plug them into the HDCVI BNC the camera is not stable and only comes on crackling and black& white. im sure this is just a setting but I cant seem to find anything about it anywhere. Please can you help Thanks C Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 3, 20179 yr comment_463602 How are they wired? Cat5 with balauns or shotgun? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463602 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 3, 20179 yr comment_463603 1 hour ago, Itsadubthing said: Hi All, Just looking for a bit of advice. We have been using the Hik-Vision stuff for a while, but due to the current issues with the new Hik we decided to try out the Dahua HDCVI stuff. I installed a DHI-XVR5104HS with some DH-HAC-HDW2401EMP cameras. The problem I am having is when I plug them into the HDCVI BNC the camera is not stable and only comes on crackling and black& white. im sure this is just a setting but I cant seem to find anything about it anywhere. Please can you help Thanks C Also dahua are very helpful , do you not have access to there tech? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463603 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 3, 20179 yr comment_463606 my first check would be connection or psu. Did u have connection issues with hik too? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463606 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 4, 20179 yr Author comment_463611 no never, and when i swap the bnc to the analogue end the picture is fine (low quality but fine) my first though was my BNC's. Its a brand new 2Ah psu but again I have tried another one also. 11 hours ago, Lwillis said: How are they wired? Cat5 with balauns or shotgun? shot gun cable Edited June 4, 20179 yr by Itsadubthing Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463611 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 4, 20179 yr Author comment_463612 10 hours ago, al-yeti said: Also dahua are very helpful , do you not have access to there tech? I was just looking for a quick reply over the weekend Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463612 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 4, 20179 yr comment_463613 Could be a few things as above check the psu,bnc ends is it copper cable or the chepo stuff? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463613 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 4, 20179 yr comment_463614 Seen something similar before. The camera has two outputs... HD-CVI and CVBS, looks like your in the opposite one to what the input is set as. Switch it and see what you get. *just saw the above post and you already have done. Check the input is set to HD-CVI and not analogue within the DVR settings. Can't remember where in the menu but can check one later if your struggling. Edited June 4, 20179 yr by ElecTech Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463614 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 4, 20179 yr Author comment_463615 13 minutes ago, ElecTech said: Seen something similar before. The camera has two outputs... HD-CVI and CVBS, looks like your in the opposite one to what the input is set as. Switch it and see what you get. *just saw the above post and you already have done. Check the input is set to HD-CVI and not analogue within the DVR settings. Can't remember where in the menu but can check one later if your struggling. thanks for your suggestions ElecTech, im sure its just an input set wrong but searching through all the menus i cant seem to find anything. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463615 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 4, 20179 yr comment_463617 Try to set all inputs as CVI and see if anything changes. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41271-dahua-newbie/#findComment-463617 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
