May 6, 20179 yr comment_462581 Hi I have an Optima/Accenta and in the last few days the alarm has just started going off for now reason (at midnight but at 3am yesterday). i have 8 zones and the panel reads like this after it has been reset 12345678 TP F0000000 00 Would really appreciate some help and advice. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20179 yr comment_462582 Hi, The display is showing zone 1 as currently open, so if this is what the displayed showed when you disarmed it I so would suggest its an issue with zone 1. Have a look at the detector that is zone 1, does there appear to be any damage to it or the cable that goes it it? Obviously speculating here & would need to be checked out properly but very possibly a faulty detector and or cable .. Edited May 6, 20179 yr by aissecur more info Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462582 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20179 yr comment_462583 Is zone 1 a door contact? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462583 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20179 yr comment_462584 1 hour ago, KB RED said: Hi I have an Optima/Accenta and in the last few days the alarm has just started going off for now reason (at midnight but at 3am yesterday). i have 8 zones and the panel reads like this after it has been reset 12345678 TP F0000000 00 Would really appreciate some help and advice. Can you not scroll through the "log" to see what activates at night? Or perhaps system battery Or as you say zone fault Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462584 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20179 yr Author comment_462590 Wow - thanks for fast replies! Ok - when it went of I just put in the code to I set. Saw that error message and then pressed reset and the message then went and the display said 'system unset' i will check out the pir and the cable (the battery was changed 2 years ago) i will now check the log and see what that says and get back on here with the report. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462590 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20179 yr comment_462592 Or is zone one the PIR adjacent the keypad and picking them up? Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462592 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20179 yr comment_462596 I was going to say, 'fault' is stretching it a bit far as I assume all these range of panels are global tamper only*, so 'open (for whatever reason)' seems a more appropriate comment to make. *There was one, single, rareish, Optima that supported EOL though wasn't there? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462596 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20179 yr comment_462599 6 hours ago, KB RED said: Wow - thanks for fast replies! Ok - when it went of I just put in the code to I set. Saw that error message and then pressed reset and the message then went and the display said 'system unset' i will check out the pir and the cable (the battery was changed 2 years ago) i will now check the log and see what that says and get back on here with the report. Thanks That don't make sense , you mean you have entered walk test and that's what picked you at keypad Must be getting old , I am sure in my earlier house bashing days that was walk test procedure , so better you look at log dude and find out why it's going off Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462599 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20179 yr comment_462605 6 hours ago, datadiffusion said: *There was one, single, rareish, Optima that supported EOL though wasn't there? Accenta ABI supported EOL, there's also the iD Accenta that catches a few people out, as it seems... Trade Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462605 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 7, 20179 yr comment_462607 Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41205-alarm-fault-code/#findComment-462607 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
