Wireless alarm signal
do they, anyone used it. How do you program it up?
Through the 'Ricochet only' serial port via Wintex I guess?
It looks like you need a conventional expander AND a relay card that simulates the panel...
http://www.texe.com/uk/uploads/Expansion_Kits_Booklet_Web_4.pdf
Edited by datadiffusion
4 minutes ago, petrolhead said:
The pyronix ones i suggested are 2 way.
Trying to get into Jimmys good books, eh?
He has! Delighted to confirm a 52 pence Security Warehouse discount voucher is available for you to collect (in person from TSI HQ) as we speak!
Last time I looked you did not need Wintex to program the standalone receiver as it provides the on board relays and its a push-button learn as as Pyronix one.
Out of interest what are the 2 panels installed?
Ah right, never used the standalone part, just an expander (once). There is a Ricochet > Wintex port on board the expander though isn't there, or am I imagining it?
So you finally swerving to texe?
There is a port to connect your usb lead and I would imagine it would work with Ricochet monitor, never tried (but i will when i get 5).
You learn the devices with the on-board push button and the leds.
