Texecom com wifi
  • Replies 37
  • Views 13.1k
  • sixwheeledbeast
    sixwheeledbeast
    If it's open then it's likely a setting in the app or the settings in Program Digi then.
  • sixwheeledbeast
    sixwheeledbeast
    Probably No
  • sixwheeledbeast
    sixwheeledbeast
    Gateway is the IP of your gateway, DNS is the IP of the DNS server. If using a BT router these are likely to be that.     Probably not advised if you have no networking skills. I
6 minutes ago, sixwheeledbeast said:
Someone with a bad experience...
Manual is pretty comprehensive from memory.
You could say that!!! We've got thirty odd systems out there and everyone was a mare to set up.
We've stopped using Texecom now if the client requires an app and remote control and are now using HKC, it takes 5 minutes to set up and their tech support is spot on, no 20 minute wait on the phone. AND there are several things missing from the Texecom WiFi com manual and the main manual that are VITAL to its remote operation/notification, their tech support (when you can get through to them) confirmed there was stuff missing back in January this year and says the manuals will be updated sometime in the future.
Probably waiting for Connect.
Never had an issue with them and I have fitted more than that.
App is clunky but I'm not one for apps anyway.
i have a hkc at home and the app is flawless
I write the manuals, please tell me what's missing from your perspective? ASFAIK nothing is missing.
[email protected]
Head of Industry Affairs
Visit Our Website
Texecom
Home hubs are dire for port forwarding.
You may remember my apocryphal tale where, unknown to me, the HH objected to the use of the word 'CCTV' as a description; it just would not work whenever that phrase was used, it wasn't just a one off either, any new ports using that name would not work. They had to be deleted and recreated using any other name to work.
Suspect this has it's origins in drop down menu (built in) port forwarding settings using the same label.
  • 3 weeks later...
Adrian Its the extra info that you have to put into the panel since the version 3 update
Its all a bit of a moot now anyway as the company has now been purchased by SPY alarms and I quit Friday, so Spy's problems now not mine!! :-)
Edited by Flossyrockstar
Yeah the BT home hub 5 is a pile of pooh!!
Why did you quit buddy? Spill the beans :huh:
That's only the encryption the unit will function correctly without it. (I don't agree it should, but that's another story)
You make the app generate the key and type the Hex into Engineers Utils.
The manual refers you to the full manual to do this, I recall.
