Apollo 65 SD on Galaxy
  • Replies 73
  • Views 19k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Each battery powered smoke alarm has its own sounder, should it detect a fire it makes a noise   A 12v intruder alarm has the sounder separate from the detection device, combustible cables m
  • Shaunb1905
    Shaunb1905
    Must be mental using twinflex!!
  • grade D can be connected to their own dedicated circuit or a regularly used lighting circuit   my preference is with the lights, more so because if there is a fault its usually noticed soone
Posted Images
Aico mains interlinked, one with radio base, aico 414 fitted somewhere where a cable can connect to intruder system, IE next to alarm panel, job done.
4 hours ago, james.wilson said:
it is 5839 btw
heheh not sure where 8579 came from
All comments considered I think i am going to go ahead with my original plan of installing on intruder alarm system, fully accepting any repercussion of my actions.
At least you guys can be satisfied you 'warned/advised' me of any potential consequences of doing so.
Failing that I will just stick it on 3 amp FCU, which i understand is grade D as you gentleman pointed out.
On 7 January 2017 at 9:27 PM, james.wilson said:
id agree I have wireless hkc in 3 places. Plus they have sounders built in and can operate without the panel
Would a wireless HKC work on say a RF RIO or Radio ZEM on pyronix? If so sounds like a great plan.
Why not just use the Honeywell wireless for honeywell?
A bit more expensive thats all
You will not be saying that if they save your life one day!!
