Pyronix Homecontrol+ vs Visonic Powermax vs Texecom
16 hours ago, 1animal1 said:
I'm not sure where this encryption menu is? I've looked through most of the settings, read the installation manual... I can't see where to admit this information? Even the third party app doesn't ask for this info.
As an aside, I have carried out some testing today to ensure the part alarms work. All good... I found that I get phone remote notifications when the alarm is set, and when certain instances happen.
I have also found that the internal siren won't reset easily without the engineer code when exiting without closing the door within the allowed time.. therefore creating an exit fault stopping the alarm from setting. Must be a tick box somewhere to resolve?
  • Replies 312
  • Views 172.8k
I can only think is you don't have the latest firmware with an Encryption Menu then.
If you are getting messages, I imagine the app is setup and your upload speed maybe an issue for the app.
I can only assume you have engineers reset on.
How would i check that?
I've just changed the IP - no difference. When i do a test call and go through Wintex or the app on the LAN, COM1 switches to online and i get full control.... when i turn wifi off the phone, com1 still goes to online but the dot remains pink.... it's talking to it but refusing to send data, so the problem must be with the alarm.
I'm doing all this on the remote panel which shouldn't matter should it?
What about UDL options? I have M&D ticked - tried without and no difference
Am i right in saying you cannot flash the new firmware via the Texecom flash board to a 24W? I have read it on a previous post but there appears to be the firmware available on the upload selection.... I am also getting an error message saying the board isn't communicating properly - despite having followed the instructions to the letter and having updated my drivers
No, it's older (ancient) versions that can't either be flashed at all (no port) or past a certain version (not enough RAM/EEPROM space) that you might have read about.
Any Premier should be fine, AFAIK.
If there's your panel version in the flasher software your good to go.
You'll need 3.02 firmware, make sure lead is plugged on the flashing port correctly and it's detecting your COM lead. Flick switches and buttons as required via instructions.
Thanks chaps - I've done everything to the letter. I'm now wondering if my lead with it being none gen is FTDI chipped - figure it must be but it's still an unknown
What equipment are you using to flash the panel then, bear in mind if it all goes wrong you have bricked the panel.
I am using the CDH-0001 with a lead which has so far worked when plugged directly into the panel. All this off my laptop...
