Pyronix Homecontrol+ vs Visonic Powermax vs Texecom
Can I ask, the two arming suites that I have on the 24w. Does that mean I can set up full arm, daytime and night time? Or is that categorised as 3....
  • Replies 312
  • Views 167.1k
Essentially what I want is this. The most used part will be... Part arm A
Part arm A (daytime)... Hall, landing, garage pirs, all 3 door contacts alarmed.
Full set.... Obviously everything (default)
Part arm B (night time)... Garage pir and all 3 door contacts.
Keypad in hall. Want to use prox tags to part arm A/disarm A.
Keypad on upstairs main 24w panel, to use smart key to set part arm B for night - or I may fit another pad for convenience - as per your advice previously, these smart keys are a little bit ****... Who wants to turn a remote on before you can use the functions, seems daft.
I don't know anything about the prem but id assume you can set a keypad to arm a group only
Instructions certainly say that you can  - It's the next level down I'm confused about. Is it an area of zones I'm limited to 2 with, with the 24W panel, or the area suites - assuming they are different.
Gathering without a different code on the same remote panel, arming a 2nd part arm zone is difficult - therefore for night time arming my only other option is to have another pad upstairs or use the pad on the front of the panel - I ideally don't want to fit another pad as the panel is in the airing cupboard next to the master bedroom, therefore the smart key could become useful if you can program the part arm to part arm area B only.
Edited by 1animal1
Premiers have "Areas" the amount of these depends on the panel model, Areas are like dividing a system into little separate alarm systems.
Then each Area has 3x Part sets, these are a quick way to isolate (omit) a section of the area the part set is in. So a bedtime set, for example.
Again there are many ways to do the same thing, a skilled Texecom installer would try to make the system as easy to operate from the user perspective, but still conform to the relevant standards.
Without knowing the layout or what you need I imagine only Area A is used and two part arms.
Thanks SWB. I've read through the instructions a few times today. So I'm figuring - if i choose the attribute 'Part 1 Omit' for all the PIR's that i don't want on part arm 1 (everything bar the kitchen and livingroom PIR)- then set an area up for night time in the area suite for all the door contacts and garage PIR - will i be able to apply this area to part arm 2?
Edit - based on what you have said - if i set an area up for the daytime, then omit further PIR's from that daytime area for the night time...then that should do what i need too presumably?
Edited by 1animal1
Suites are a way of arming multiple Areas at the same time.
I rarely use Suites as most systems I would install are on Entry/Exit setting not Timed.
I would always avoid separating systems into Areas from the same keypad, for other reasons irrelevant for your system.
What exactly are you trying to accomplish with your system.
You need a full set and you will need a bedtime set this can be a part arm, what else do you need?
The full arm will only be used on holidays. The main use will be a part arm in the daytime as we have two dogs at home and a dog walker visiting, so all but the kitchen and living room pirs and back door contact will be on. The second part arm will be bedtime which only needs the 3 door contacts and garage pir on.... I can see how to omit in attributes, but the living room and kitchen need omitting for both part sets... It will only allow me to omit for one or the other
So you need one Area and two part sets as you say.
You can select any number of part sets to omit each zone from.
