Flush contact grade 3 for aluminium door
No not tried them for a while, I have quite a few older ones which I've been saving up for my own place where speed and ease of installation is less of an issue...
  • Replies 30
  • Views 7.4k
  • PeterJames
    PeterJames
    Just because it has a high number (In comparison to G1 G2) its not necessarily the best, fitting G3 in many cases makes the system less reliable. G3 contacts are sided and are much less forgiving when
  • Not sure how this helps the OP ?
Fair point.  As we managed to cram in so many different panel options / double door config / TACT tamper and MID for G3 , the orientation of the arrowed resistor modules can be a little fiddly.  Although they are shipped out as Galaxy config by default, if that helps...
Edited by spike27
Not for an i-On user :)
Am winding things down on the security front if I'm honest, but next time might give them a go again to see what the new ones are like.
Where you going ? Work for trump?
Nah Trump wannabes probably though.
Be doing more property maintenance type services.
But strictly not rental / HMO type work.
Edited by datadiffusion
Never did do fire, intruder / access will only be 'by invitation '.
access by invitation only. What you got into now?
Well hmo has plenty of that , or you doing the building work, more money in that
Fire proof equipment makes good money, I sell a few fire retardant security blinds etc to hmo can't be bothered with fire alarms though seems risky
