4 Channel Cctv Kits For £340-£400
  • Replies 33
  • Views 8.1k
  • Created
  • Last Reply
I know what you were trying to do, so why mess about and give trick comments we're all here to help and advise each other!
I think I might go for that tbh, will the image be better on the esp in terms of recording
does it come with all the cables etc?, and yes I understand its a budget system but just want to install the best system I can within the price range and required resolution
its equipment only its not a diy kit like the maplin one?
Now you really have lost me , what trick?
You asked what equipment , i was only referring to previous comments of esp equipment
You need to chill man , I already got laser sighting on one leg
thats his budget though can't go any higher thats why im asking, what are them esp kits like from security warehouse
Tell him FO, i would. Then i'd go and earn a proper days wage than **** about with that ****.
ESP is utter *****, equal to swann.
You can buy better kit off securitywarehouse.
I would have just put the phone down on him. Once you put the Vat on a days labour for one man it would almost use up his budget.
The problem is for £400 you will not get very good kit, and poor kit normally goes wrong. This means as said before you will be returning all the time trying to fix stuff you supplied under warranty. You obviously are not making any profit on the kit itself, so get him to buy the kit and you fit it, that way if the kit goes wrong you can harge him to come and take the bit down so he can take it back to the supplier and change it, then you can charge him for refitting it. If you supply the kit and sell it for the same price you paid for it all you are doing is making yourself busy for no money. Either that or you wont return his calls when it goes wrong and he wont b recommending you to anyone. Personally I would walk away his budget is not enough to achieve a reasonable system. Cheap CCTV is like filling your car up with water instead of petrol, it gives the impression that you have a full tank, until you try driving somewhere.
im desperate for work mate, theres **** all round here
Where are you? Everyone I know is busier than a Asian kiddy in a Nike factory
