Csl's M2M Sim Registration Portal Database Leak
On 1st May this year, I found it was possible to dump the names, addresses, emails, usernames, and phone numbers of every single user of every single company who had registered on the CSL M2M SIM page. I did not push the investigation any further, but worse may have been visible.
http://cybergibbons.com/alarms-2/customer-database-leak-on-csl-dualcoms-sim-registration-portal/
If you would like to know if your company was one of the listed ones, I can check for you.
I have been sent a free sample sim - I didn't register though, so I wonder if the same database is used for internal purposes (unlikely, but possible)
Have a look for 'Casa Security'...
Number 25, Bristol area?
Should you wish to register...
IIRC it asks you if your co is already registered,
I clicked yes & select postcode of a local co.
& it shows you who at that co, is already signed up
Yes - IMO it still leaks data that it shouldn't. The problem was before it used to send the client all of the data in the background. You couldn't see it in the plain, but it was sent.
There's only a few options here:
1. They haven't been pentested. You'd kind of think the biggest signalling provider in the UK would do it.
2. They have been pentested by someone incompetent. If they gave money to the people who developed apprentices4fs.com, this is plausible.
3. They have been pentested and ignored all of the findings.
Who knows?
FYI, on the 23rd November, the CSL Dualcom CS2300 report is being published.
How about Alarming Company or Wakefield Security?
Fareham and Worthing? Both there.
CG
what is pentested?
and whats the report on?
Pentested means penentration testing, i.e. you get someone who knows how to hack to have a crack at your systems. I'd argue that even ARCs should be having them done (I've done a few now, and found a lot of problems, most easily fixed), but signalling providers with centralised receiving, like CSL and WebWayOne, should definitely be pentested.
The report is about the encryption and general security of the CSL CS2300 signalling units.
