Hello Benny, I am checking out the cable distributors thoughts on their particular brands and apparently they conform to a European standard and despite not being copper in total (the cores are aluminium with a copper coating) they reach the standard of 10 ohms at 100 metres, which is more than adequate for a domestic property..so, no worries on branded there. I should imagine that you would be paying a great deal more for solid copper (keeping the costs down)but it's your choice at the end of the day.
thats not correct there is a bs std now for cable, en does not have a cable std
Suspect confusion of EN with CE marking. Any old tat easily attains a CE mark, especially when self certified funny enough...
Sorry just one more question. I'm probably being thick and naive but I can't see anything in the following off about the 48w having any wired zones:
Thanks all once again!
Edited by MrHappy
link removed
Thanks. And thanks for the quick replies. Gives me a lot of things to mull over.
Now I just need to look at placement of pirs on my place. Every bloody corner looks out onto a window or a rad or is somewhere near a rad lol!
Hello Benny, "..thats not correct there is a bs std now for cable, en does not have a cable std.." whatever, just go with the information from the manufacturers as mentioned previously..it's no big deal as long as you have 10ohms @ 100mtrs the rest may be viewed by most people as 'nit picking'... but it's up to you.
CCA cable is harder to work with, as it often has a cheaper and less flexible outer jacket, often poor quality, and prone to being fragile at terminations as aluminium is.
OP, do yourself a favour and spend a couple more pounds - that's all it is - on quality, copper cable. You won't regret it!
Edited by datadiffusion
Register a new account
Sign in
