rawsons0 Posted August 31, 2015 Share Posted August 31, 2015 hi new to this has you probably guessed today i tried to set my paragon plus alarm and although chime light is on and power light the digit led is not on either of my control panels so when i press digits to set i get the beep but thats it alarm will not set i have taken cover off main control panel and alarm goes off tested battery ok anybody have any ideas what could be wrong thanks in advance geoff Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/ Share on other sites More sharing options...
PeterJames Posted August 31, 2015 Share Posted August 31, 2015 Its a paragon plus thats whats wrong Even Pyronix have stated they wont support these any longer as theyre obsolete. I think its because they were never very good to begin with Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-428989 Share on other sites More sharing options...
norman Posted August 31, 2015 Share Posted August 31, 2015 My bil has had one for the last 15 years or so, never missed a beat Tbf. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-428990 Share on other sites More sharing options...
datadiffusion Posted August 31, 2015 Share Posted August 31, 2015 Is that because it's disconnected? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-428996 Share on other sites More sharing options...
norman Posted August 31, 2015 Share Posted August 31, 2015 No Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-429001 Share on other sites More sharing options...
datadiffusion Posted August 31, 2015 Share Posted August 31, 2015 Oh So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-429015 Share on other sites More sharing options...
charlie6 Posted September 1, 2015 Share Posted September 1, 2015 Hello Rawson, there's not much to go wrong with this panel, used it with no problems whatsoever. brilliant panel just goes on working for years. Check your user instructions first of all to get rid of the chime light and we'll go from there. If you haven't renewed the standby battery within the last say three or four years you should do so now, regardless of it's reading. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-429022 Share on other sites More sharing options...
al-yeti Posted September 1, 2015 Share Posted September 1, 2015 Out of curiosity, did your alarm used to chime? As above its an old panel and its totally incorrect to say that not much will go wrong This is a good time to update it , May work out cheaper as you have cables in place and May work out Give your front door sensors a slap while your at it...... I learnt that from someone here, or get a hole cutter and I explain what to with that later Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-429033 Share on other sites More sharing options...
james.wilson Posted September 1, 2015 Share Posted September 1, 2015 the reason for tapping the contact on the door is as reeds age they can stick in closed position. Shows you have a failing door contact. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-429035 Share on other sites More sharing options...
charlie6 Posted September 1, 2015 Share Posted September 1, 2015 hello Rawson, I haven't read anything in your post which suggests a problem with the front door, however 'tapping' it is only a temporary measure.A front door contact is exposed to extremes although it is 'indoors'. It should be dismounted and the connections checked for corrosion and cleaned up, but I don't see that this has any relevance to your present dilemma so you can leave that for now. As mentioned in my previous post, look at the user instructions in order to extinguish the 'chime', it's only two key presses. You should be able then to reset by pressing your user code twice. It appears, as I said earlier, that the problem is minor and your panel should be good for another few years. Some people at the first sign of a problem tend to pay good money for a replacement panel rather than solve the very minor problem. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39023-paragon-plus/#findComment-429057 Share on other sites More sharing options...
