dwdave Posted August 1, 2015 Author Share Posted August 1, 2015 I think I'll be ending up with around 30 but I'm using a few rios to reduce runs and increase op. I have about 4 in place at the moment but will likely end up with more. Especially if I go wireless in some areas. 'till the next question ... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425950 Share on other sites More sharing options...
Nova-Security Posted August 1, 2015 Share Posted August 1, 2015 I think you have badly designed your system, using rios to reduce runs only makes sense and saves money if you have 8 circuits that are 100m away from the panel. A GD48 would have give you 16zones onboard and 4 rios and the software on the panel is more suited to a home then a 500/520 which are aimed more at high security installations that need other things. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425963 Share on other sites More sharing options...
dwdave Posted August 1, 2015 Author Share Posted August 1, 2015 I had a job lot of rios so I wasn't to bothered about that. Equally it gives me lots of little runs that can easily be replaced or moved later if required. Agreed its not the best way though. Bear in mind that 1 rio was going to be used for integration to my raspberry pi however I have only briefly looked at the galaxy app and not sure what that can do for me at the moment. I believe I need the ethernet module for that to work. 'till the next question ... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425966 Share on other sites More sharing options...
charlie6 Posted August 1, 2015 Share Posted August 1, 2015 How do you definitely and without doubt know that it is a panel fault... anybody ? DWdave have you checked the panel (see earlier post) ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425978 Share on other sites More sharing options...
al-yeti Posted August 1, 2015 Share Posted August 1, 2015 He is still better of with the dimension Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425982 Share on other sites More sharing options...
datadiffusion Posted August 1, 2015 Share Posted August 1, 2015 or texe So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425986 Share on other sites More sharing options...
Nova-Security Posted August 1, 2015 Share Posted August 1, 2015 How do you definitely and without doubt know that it is a panel fault... anybody ? DWdave have you checked the panel (see earlier post) ? Could be due to the fact that he has checked the fuse's and the panel doesn't stay on when the mains is removed. Not a panel fault more the smart rio inside the 500 www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425988 Share on other sites More sharing options...
al-yeti Posted August 1, 2015 Share Posted August 1, 2015 or texe True there software is better as is hkc , Honeywell need to develop it more Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425989 Share on other sites More sharing options...
Nova-Security Posted August 1, 2015 Share Posted August 1, 2015 Honeywell need to develop it more In what way ? can do anything with galaxy if you know the panel www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425995 Share on other sites More sharing options...
charlie6 Posted August 1, 2015 Share Posted August 1, 2015 Nova Security "...Could be due to the fact that he has checked the fuse's and the panel doesn't stay on when the mains is removed..." Fair comment, missed that post, This is hypocritical but it might be worth checking the panel in it's last known good configuration without the rio's. "....Not a panel fault more the smart rio inside the 500..." That was my reasoning at Post 20. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38862-what-should-happen-during-power-cut/page/4/#findComment-425997 Share on other sites More sharing options...
