Just fitted a one of those new ComWifi modules to a Texecom premier last week.
Realized it will need a static address, the customers router does not support DDNS updates.
Does anybody know of a solution to keep DDNS updated without running a PC windows client?
I attempted to plug on a spare netgear router that can do no-ip DDNS updates, but as soon as you put it to access point mode, DDNS gets disabled.
If it's going to be an issue, we'll end up replacing his router
cheers
Thanks for the quick replies, that's quite a clear answer
Will stop fannying around and replace the router then. Will put in a Netgear, we've got a batch of no-ip's so that'll work fine
Confused i am.
You don't need DNS, if using push notifications we track the IP address and update every time you connect, that's why the system is polled every 15Mins. I assume you are using this for the customer to have the APP. If not please explain some more.
amealing@texe.com
Head of Industry Affairs
Visit Our Website
Texecom
can panel send emails ?
