petrolhead Posted July 7, 2015 Share Posted July 7, 2015 I forgot the 9448 was the bum basic version, you might be ok. Walk test first and report back. Do you have any electrical knowledge? Can you work a multimeter to measure voltage and resistance? But tbh a pro is best. The last thing you want is to cause a short, electrocute yourself or have a system that false alarms or fails to perform when needed. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted July 7, 2015 Share Posted July 7, 2015 Accenta mini g4 bell box an pirs, les thank £100 get it fitted in about 2 hours fir less than £100 Pretty stable for a cheap replacement really Come on man, you won't cable 8 zones under floors in 2hours You fit direct under carpet? Everything on skirting clipped? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted July 7, 2015 Share Posted July 7, 2015 Come on man, you won't cable 8 zones under floors in 2hours You fit direct under carpet? Everything on skirting clipped? I assume new devices on old cables, he's also self employed ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
goncall Posted July 7, 2015 Share Posted July 7, 2015 I assume new devices on old cables, he's also self employed ? im guessing old devices on old pcb and big hole,id say 200 is too much Quote Link to comment Share on other sites More sharing options...
MrHappy Posted July 7, 2015 Share Posted July 7, 2015 im guessing old devices on old pcb and big hole,id say 200 is too much I'll PM you definitive guess Quote Mr Veritas God Link to comment Share on other sites More sharing options...
goncall Posted July 7, 2015 Share Posted July 7, 2015 I'll PM you definitive guess #roughasfck Quote Link to comment Share on other sites More sharing options...
al-yeti Posted July 7, 2015 Share Posted July 7, 2015 Change keypad for that much Quote Link to comment Share on other sites More sharing options...
Shanemaldwyn Posted July 7, 2015 Share Posted July 7, 2015 My bad, I should of said to use existing cable if prooved ok, and not full re-wired system Quote Link to comment Share on other sites More sharing options...
Adi Posted July 7, 2015 Share Posted July 7, 2015 Accenta mini g4 bell box an pirs, les thank £100 get it fitted in about 2 hours fir less than £100 Pretty stable for a cheap replacement really Thats ridiculous. Quote I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
Shanemaldwyn Posted July 7, 2015 Share Posted July 7, 2015 What is? In what way? Quote Link to comment Share on other sites More sharing options...
