stelmo Posted February 15, 2015 Author Share Posted February 15, 2015 RL2 by the looks of it which looks to be linked closely to the loop circuit Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 15, 2015 Share Posted February 15, 2015 Whats it programmed as? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
stelmo Posted February 15, 2015 Author Share Posted February 15, 2015 Whats it programmed as? Not sure I understand the question Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 15, 2015 Share Posted February 15, 2015 Not sure I understand the question Possibly as above the relaybhas been programmed to do something under certain conditions or something , if that's possible check what the relay is set to do Quote Link to comment Share on other sites More sharing options...
stelmo Posted February 15, 2015 Author Share Posted February 15, 2015 I dont see anything relating to relays, but i will have another look when I get a moment Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 15, 2015 Share Posted February 15, 2015 On the panels I know the outputs/relays are programmable id guess its set to do that Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
morph Posted February 15, 2015 Share Posted February 15, 2015 Are you shure the loop is ok and its not the panels loop isolators operating. Quote Link to comment Share on other sites More sharing options...
stelmo Posted February 15, 2015 Author Share Posted February 15, 2015 Im only running with 2 detectors on a small run of cable, i will swap the detectors over with some spares I have From what I can gather the Gent nano panel is very cut down from the stuff you guys probably deal with and as such quite straight forward menus, but i will look again and see if I can see anything thats responsible for this clicking I might also try the loop with no detectors at all in the bases and see if it still clicks Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 15, 2015 Share Posted February 15, 2015 i still go with its a heartbeat for a bms low end Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Nova-Security Posted February 16, 2015 Share Posted February 16, 2015 Are you shure the loop is ok and its not the panels loop isolators operating. If you have it on a bench and the loop is made up of a couple of meters of cable, the loop may be to short and resistance of the loop is not enough for the panel. Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
