Gent Panel Clicking Every 60 Seconds
  • Replies 51
  • Views 31.8k
  • possible causes of a "chattering relay"   relocating a London relay to Scotland - relay is cold turn up heating until its acclimated ? relocating a Scottish relay to London - Irn-Bru & Battered
  • If you haven't got anything constructive to add to the discussion regarding the initial post then please don't bother, I can assure you I'm well aware of certain fire alarm engineers that frequent for
  • Pleased to see you are giving as good as you get there.   As for the fault I have never known any addressable fire panel do that with no faults but I cant see how you have it wired or what its wired
Not sure I understand the question
Possibly as above the relaybhas been programmed to do something under certain conditions or something , if that's possible check what the relay is set to do
On the panels I know the outputs/relays are programmable id guess its set to do that
Im only running with 2 detectors on a small run of cable, i will swap the detectors over with some spares I have
From what I can gather the Gent nano panel is very cut down from the stuff you guys probably deal with and as such quite straight forward menus, but i will look again and see if I can see anything thats responsible for this clicking
I might also try the loop with no detectors at all in the bases and see if it still clicks
i still go with its a heartbeat for a bms low end
Are you shure the loop is ok and its not the panels loop isolators operating.
If you have it on a bench and the loop is made up of a couple of meters of cable, the loop may be to short and resistance of the loop is not enough for the panel.
www.nova-security.co.uk
www.nsiapproved.co.uk
