Wiring A Pir And A Magnetic Contact In Parallel?
buzzer
Or tragic. Whichever the outcome :(
But Stuart to a degree, if they end up burnt to death in a house fire or electrocuted there's only one person to blame. Clearly an electrician has told them what needs doing but rather than spend £100 to get the job done right they want to spend £8 saving a massive £92. Thing is, dead it's not much use to them but diynot knows best eh.
Not going ahead with a quote is one thing, but, worse than that, the forum means they never speak to the electrician who tells them
the forum advice is a pile of ****, or even several if they don't believe the first one...
Edited by datadiffusion
It's frightening. I'd have that website banned and the likes of it. Breakers trip for a reason and that reason needs to be found and put right. Going to wait until someone touches the light switch and ends up on the other side of Pluto?
I had an electrical problem of my own however found a fluke wasn't necessary to diagnose :)
I have a six way extension behind my pc in the house and each morning my wifi was offline and it's plugged in to the same extension so took a look and the switch was off. Flicked it back on and same happened again the following day. Puzzled put it back on and sure enough day after same again. I listen to the radio via tune in and the stream just stopped so I goes to investigate and the cat is sat with its paw on the switch as it's a thoroughfare to the cupboard where he's started sleeping :)
