Power To The Diyer!
Well that's one way of ensuring it isn't unplugged accidentally, Little transformer backed up by a 32A fuse, nice.
That flex will make a glowing fuse wire
Edited by matthew.brough
But then, how often do you see a door bell transformer alongside the CU wired to a 32amp rcd with twin bell wire?
BS approved Bell transformer is exempt AFAIK, if wired direct to 5A or 6A?
Might be making that up ;)
that shocks me if true boom! boom!
personally, sod that for a game of tin soldiers, if i fit one, has to have spur or plug, 3 amo fuse max
i have always assumed the CU being mounted on a lump of timber is for insulation needs, or to get cables behind, but us that correct and still required? just tweaked my curiosity for some reason.
  • 2 months later...
bell transformers have some exceptions but not off a 32 amp ring main mounted next to it lol, some transformers now made to fit directly into cu been around for a while tho
  • 6 years later...
