Risco Agility 3
paul44
Our experience of the Agility 3 improves each install, the problem with lost signal or lost camera is an error message, the latest batches will be adjusted, but for current product, go into the systems menu and adjust the report time, current the report time is factory set at 58 minutes, the devices has to be "seen" twice in any rolling 2 hours, adjust this to 15 minutes, ie more attempts within the 2 hour slot and problem goes away......magic! in terms of the GSM that remains a mystery, except is was found that one of the SIM clip legs was in our case bent. Lastly short battery life in door contacts, this is due to diode damage where someone has connected the battery in the wrong way around for a few seconds, apparently the device is not polarity protected and if you look at the pcb under a magnifier one can see the damage, be more careful LOL
R u rep for riskyo?
