Dedicated Spur?
Guest Guest
That post gets an award.....
First post by Arfur Mo that fits on a normal screen, so can be read easily.
Bit of friendly advice AM - keep it short and sweet. :whistle:
so what your saying is 'less is more' :hmm: i agree - pity i can't convince the wife B)
but thanks for reading my 'tombs'. soz they get a bit long but it was a serious subject - to me at least :rolleyes:
regs
arfur_mo
use C curve to prevent lamps blowing the B curve MCB's
After calculating that a type C MCB will still provide adequate protection in line with the original design spec. ;)
  • 2 weeks later...
Guest Guest
Shouldn't the supply to the spur be in 2.5mm as it's rated at 13Amps?
Obviously lighting ccts ain't usually wired in 2.5mm :hmm:
Regards
Bellman
Are you joking!! all that is needed for an alarm maximum is 3amps
I know this, I was refering to the spur, not the alarm ;)
