ferg Posted January 5 Share Posted January 5 Hi All Happy new year would like to install 1xuniview poe switch outside in a waterproof box just so i dont need to have 12 +cables coming inside house as restricted access are there ways round to stop poe switch not working correctly due to uk weather heat or cold temps,i know box is waterproof would like any sugestions if anyone has succesfully done this or is it you have to use a proper external poe switch any info would be appreciative Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47427-exterior-poe-switches/ Share on other sites More sharing options...
james.wilson Posted January 5 Share Posted January 5 If you have power you could fit a little temp controlled heater. Only ever fitted them inside securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47427-exterior-poe-switches/#findComment-531494 Share on other sites More sharing options...
al-yeti Posted January 5 Share Posted January 5 53 minutes ago, ferg said: Hi All Happy new year would like to install 1xuniview poe switch outside in a waterproof box just so i dont need to have 12 +cables coming inside house as restricted access are there ways round to stop poe switch not working correctly due to uk weather heat or cold temps,i know box is waterproof would like any sugestions if anyone has succesfully done this or is it you have to use a proper external poe switch any info would be appreciative I have used different types , London tho , never had an issue except a cheaper version died after 10 years , used different types of IP box Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47427-exterior-poe-switches/#findComment-531495 Share on other sites More sharing options...
MrHappy Posted January 5 Share Posted January 5 The storage & operating temperatures of the equipment will be stated on the data sheet. Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47427-exterior-poe-switches/#findComment-531496 Share on other sites More sharing options...
sixwheeledbeast Posted January 5 Share Posted January 5 Outdoor ones are at least triple the cost? I have put internal equipment (AP) outside in an IP box at customers request, it lasted couple of years before it lost it's marbles. I'd suggest that's a lot of equipment to go down if you have a failure and consider a redesign or using the proper stuff. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47427-exterior-poe-switches/#findComment-531497 Share on other sites More sharing options...
PeterJames Posted January 5 Share Posted January 5 37 minutes ago, james.wilson said: If you have power you could fit a little temp controlled heater. QFA id go for a camera heater in the WP Box just make sure its mounted properly not just sitting in the bottom of the box where it will melt through Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47427-exterior-poe-switches/#findComment-531498 Share on other sites More sharing options...
