SecM Posted Tuesday at 11:29 Share Posted Tuesday at 11:29 Hi, Is there a recommended way to attach 3 x wired Deltabell X to the Enforcer v.11 panel? Either directly or with additional hardware? The kit has been bought some time ago so looking to make use of it. Many thanks, M Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/ Share on other sites More sharing options...
PeterJames Posted Tuesday at 16:28 Share Posted Tuesday at 16:28 The answer is yes anything is possible, you would need an additional power supply and battery. But the question is why would you want to? Bells go wrong and when they do theyre a nuisance, Id much rather have a system with no bell and decent coms, certainly not three. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-530990 Share on other sites More sharing options...
MrHappy Posted Tuesday at 16:52 Share Posted Tuesday at 16:52 5 hours ago, SecM said: Is there a recommended way to attach 3 x wired Deltabell X to the Enforcer v.11 panel? https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/intruder-alarm-ancillaries-c-36_46/pyronix-euro-zem8-psu-grade-3-p-4082.html 3 zones as bell tampers 3 outputs as sirens (the strobe flashes when the bell rings) Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-530991 Share on other sites More sharing options...
al-yeti Posted Tuesday at 17:28 Share Posted Tuesday at 17:28 59 minutes ago, PeterJames said: The answer is yes anything is possible, you would need an additional power supply and battery. But the question is why would you want to? Bells go wrong and when they do theyre a nuisance, Id much rather have a system with no bell and decent coms, certainly not three. Scb mode ? Extra PSU? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-530993 Share on other sites More sharing options...
PeterJames Posted Tuesday at 21:02 Share Posted Tuesday at 21:02 3 hours ago, al-yeti said: Scb mode ? Extra PSU? Extra current drawn when all three are sounding ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-530995 Share on other sites More sharing options...
MrHappy Posted Tuesday at 22:31 Share Posted Tuesday at 22:31 (edited) 1 hour ago, PeterJames said: Extra current drawn when all three are sounding ? I struggle to hear 1 pyronix ewd unless I open the front door, Where Gardtec sounders so much better that now I'm deaf ? Edited Tuesday at 22:32 by MrHappy Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-531000 Share on other sites More sharing options...
james.wilson Posted Wednesday at 01:47 Share Posted Wednesday at 01:47 3 hours ago, MrHappy said: I struggle to hear 1 pyronix ewd unless I open the front door, Where Gardtec sounders so much better that now I'm deaf ? i reakon if you had 3 sounders on your wireless system you would be golden? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-531003 Share on other sites More sharing options...
al-yeti Posted Wednesday at 06:57 Share Posted Wednesday at 06:57 9 hours ago, PeterJames said: Extra current drawn when all three are sounding ? Scb mode doesn't draw extra current, but I guess charging three bells is what you meant Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-531004 Share on other sites More sharing options...
Barsnake Posted Wednesday at 07:35 Share Posted Wednesday at 07:35 you could fit a zem psu and make all thre SAB and have seperate trigs and tamper BUT WHY WOULD YOU! two on SCB would work but messy especially for fault finding if that happens "If" definately needed best option two radio versions and one sab wired Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-531006 Share on other sites More sharing options...
al-yeti Posted Wednesday at 08:09 Share Posted Wednesday at 08:09 (edited) 34 minutes ago, Barsnake said: you could fit a zem psu and make all thre SAB and have seperate trigs and tamper BUT WHY WOULD YOU! two on SCB would work but messy especially for fault finding if that happens "If" definately needed best option two radio versions and one sab wired Is there not two zones on the thing? Make them into tampers But makes sense what you say To be fair no one gives a flying..... On external bells ,when they are in and door is closed you don't hear much , internal sounders are important Edited Wednesday at 08:10 by al-yeti Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47389-pyronix-enforcer-v11-and-3x-wired-deltabell-x/#findComment-531007 Share on other sites More sharing options...
