Pyronix Enforcer v.11 and 3x wired Deltabell X
Hi,
Is there a recommended way to attach 3 x wired Deltabell X to the Enforcer v.11 panel? Either directly or with additional hardware?
The kit has been bought some time ago so looking to make use of it.
Many thanks,
M
The answer is yes anything is possible, you would need an additional power supply and battery. But the question is why would you want to? Bells go wrong and when they do theyre a nuisance, Id much rather have a system with no bell and decent coms, certainly not three.
https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/intruder-alarm-ancillaries-c-36_46/pyronix-euro-zem8-psu-grade-3-p-4082.html
3 zones as bell tampers
3 outputs as sirens (the strobe flashes when the bell rings)
Scb mode ? Extra PSU?
1 hour ago, PeterJames said:
Extra current drawn when all three are sounding ?
I struggle to hear 1 pyronix ewd unless I open the front door,
Where Gardtec sounders so much better that now I'm deaf ?
Edited by MrHappy
i reakon if you had 3 sounders on your wireless system you would be golden?
Scb mode doesn't draw extra current, but I guess charging three bells is what you meant
you could fit a zem psu and make all thre SAB and have seperate trigs and tamper   BUT WHY WOULD YOU!
two on SCB would work but messy especially for fault finding if that happens
"If" definately needed best option two radio versions and one sab wired
Is there not two zones on the thing? Make them into tampers
But makes sense what you say
To be fair no one gives a flying..... On external bells ,when they are in and door is closed you don't hear much , internal sounders are important
Edited by al-yeti
