security master tp-800 pre wired alarm problems!
I read that the unused zones must me linked,so I did this too.Now all zones are with switched off leds and only the real zones switch on when sense movement.
white+black wires=normal work=switched off led.
  • Replies 77
  • Views 31.7k
  • tbf fair for 3 squid you could bang it on fleabay and get 20-30 I reckon.
  • datadiffusion
    datadiffusion
    Those instructions in full;   Turn off mains Remove battery Remove all traces of TP800 equipment Place into bin Contact a local installer, or, fit a DIY Scantron
  • datadiffusion
    datadiffusion
    Good luck with that, since you have to go back 12 years just to get a sniff of the original website...   OP, it's tat, I'd bin it. I've unwittingly taken about 5 of these out over the years,
Found the original manual in one bag in my home with the left sensors and other parts from the set.
If anyone need it I can make some scans.
Now I will try to set it up,if I have any questions I will put them in new separate thread.
Your a proper classic man
But well done for keep going and trying we wouldn't lol
I hope now to have more luck when I have the manual.
Of course If I need your help will write again.
It's shame to left it like this,because everything was mounted before years ago and just needed to be configure,but I left it like this with the idea "some day".
So this day come.
Edited by dra6ko
Everything set up and work fine.
But the manual helped a lot.There was not a chance to make something without it.
Shame that would have made a good sacrifice if we burned the panel on a stake
Just kidding yeah.....
  • 3 months later...
My system appears to function  fully but once the alarm goes off keying in the code will not stop the siren ? Ive tried changing the back up  batteries that has no effect Any ideas please
It could be a number of things could be poor connections in the bell so t6he bell is not getting enough current, do you see corrosion on the terminals at the bell? It could be the bell is knackered, it could be the panel is knackered my money is on one of the first two
5 hours ago, AMB said:
Sorry didn't mention my system is a Pre Wired Security Master
Reality get some money together and scrap it , seriously
