I read that the unused zones must me linked,so I did this too.Now all zones are with switched off leds and only the real zones switch on when sense movement.
white+black wires=normal work=switched off led.
Found the original manual in one bag in my home with the left sensors and other parts from the set.
If anyone need it I can make some scans.
Now I will try to set it up,if I have any questions I will put them in new separate thread.
Your a proper classic man
But well done for keep going and trying we wouldn't lol
I hope now to have more luck when I have the manual.
Of course If I need your help will write again.
It's shame to left it like this,because everything was mounted before years ago and just needed to be configure,but I left it like this with the idea "some day".
So this day come.
Edited by dra6ko
1 hour ago, dra6ko said:
Everything set up and work fine.
But the manual helped a lot.There was not a chance to make something without it.
Shame that would have made a good sacrifice if we burned the panel on a stake
Just kidding yeah.....
  • 3 months later...
It could be a number of things could be poor connections in the bell so t6he bell is not getting enough current, do you see corrosion on the terminals at the bell? It could be the bell is knackered, it could be the panel is knackered my money is on one of the first two
Register a new account
Sign in
