Advantage of CAT6 cable over CAT5 ? Voltage drop over length of run?
What is the advantage of using CAT6 cable over CAT5 for an IP camera system please"
Also at what sort of length run should I be concerned about voltage drop please? I don't think my runs will exceed 40, possibly 50 metres? Again to run IP cameras.
Thanks again for any useful comments 🙂
None. The uneducated will say it makes a difference it won't. If you plan on breaking gigabit per channel I'd like to know how
Depends , if you had remote switch couple of nvrs your wouldn't want a cat5 between them right ?
I'd prefer a cable for all options. I don't see the advantage of CAT6 for cctv over CAT5. I'd also suggest that even if cctv per channel needs more that 1gbs that CAT5 will be 10gig. Copper wins imo over short distances over fibre. I reakon that's true for my lifetime
