Bending Springs or Device for Aluminium Security Conduit
Hi
Am after some way of putting up to 45 degree bends in my aluminium conduit.  I am in the UK, the conduit measures around 13mm external and about 12mm internal - standards stuff available form ADI.  I use the 90degree and couplers already.  When I ask they say computer says no, to 45degree bends.
I tried micro bore plumbing pipe benders but the formers were not Goldy Locks, not quite right; that resulted in the pipe kinking or not fitting in the former.
Or maybe you know of a 45degree manufactured bend available?
Cheers
John
I dont think you can bend alli tubing much the only bends I can find are these https://www.securitywarehouse.co.uk/catalog/cctv-c-1/cctv-ancillaries-c-1_3/secware-aluminium-tubing-12mm-single-elbow-p-6071.html
45image.png degrees is a bit of a strange angle for running alli tubing though its a bit tight squeezing/pulling a cable through it too?
ali tube is 12.7mm aka 1/2 inch
you need a 1/2 inch spring, however it don't bend very well as it right cheap & nasty shite compared to what it used to be....
So I doubt your going get 45°
1st result in google - https://www.ac-one.co.uk/tube-bending-springs-1281-p.asp
Post a picture of what your doing we can take the piss ?
It's not the right type of aluminium for bending clean.
Not sure why I would ever need 45 but anything complicated I'd probably consider 20mm.
you need a 1/2 inch spring, however it don't bend very well as it right cheap & nasty ***** compared to what it used to be....
Lol, cheers.  Purchased, will see how i get on, absolutely will send pics piss can and am sure will be taken ?
why  45° ?
I used to use a bending spring years ago but it won't work on it now as the walls are too thin
On 22/08/2023 at 20:32, MrHappy said:
why  45° ?
I have manufactured 90degree bends, i need 45 to set around some stuff, might get away with less thouh.
Okay so gave it a try and the spring is a good fit, i cannot get to 45 but i can get to 25 / 30 before it kinks or in one case snaps.  I will give it a go for real when i am next on site.
Will ping some pics on this thread if it is still open.
Thanks again all, appreciate it.
John
