james.wilson Posted September 22, 2023 Share Posted September 22, 2023 Normally your final exit doors would be 'final' you entry route zones would be exit. The use intruder for the rest not on the entry /exit route 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Grego Posted September 26, 2023 Author Share Posted September 26, 2023 Starting to wire up the window zones (as previously discussed). My existing system (see photo below) had resistors across the common pin and zone pin (circled in blue), and a resistor in series with the windows (circled in red). That is because my current system is zone doubling. I assume on the new galaxy FX100+ (because I am not planning on zone doubling) I just follow the diagram as previously discussed here in my Previous Post and will only need a single 1k resistor as per the one circled in red above? Hate to keep asking, so please excuse my questions. Once I have my head around this for one zone I will be fine. Quote Link to comment Share on other sites More sharing options...
Grego Posted September 26, 2023 Author Share Posted September 26, 2023 On 22/09/2023 at 20:18, james.wilson said: Normally your final exit doors would be 'final' you entry route zones would be exit. The use intruder for the rest not on the entry /exit route Thank you James, much appreciated. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted September 26, 2023 Share Posted September 26, 2023 19 minutes ago, Grego said: Starting to wire up the window zones (as previously discussed). My existing system (see photo below) had resistors across the common pin and zone pin (circled in blue), and a resistor in series with the windows (circled in red). That is because my current system is zone doubling. I assume on the new galaxy FX100+ (because I am not planning on zone doubling) I just follow the diagram as previously discussed here in my Previous Post and will only need a single 1k resistor as per the one circled in red above? Hate to keep asking, so please excuse my questions. Once I have my head around this for one zone I will be fine. Nice wiring.... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted September 26, 2023 Share Posted September 26, 2023 1 hour ago, Grego said: Starting to wire up the window zones (as previously discussed). My existing system (see photo below) had resistors across the common pin and zone pin (circled in blue), and a resistor in series with the windows (circled in red). That is because my current system is zone doubling. I assume on the new galaxy FX100+ (because I am not planning on zone doubling) I just follow the diagram as previously discussed here in my Previous Post and will only need a single 1k resistor as per the one circled in red above? Hate to keep asking, so please excuse my questions. Once I have my head around this for one zone I will be fine. Speaker wire? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted September 26, 2023 Share Posted September 26, 2023 1 minute ago, al-yeti said: Speaker wire? dunno, TBH I couldn't give a Castlemaine 4x 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Grego Posted September 26, 2023 Author Share Posted September 26, 2023 1 hour ago, MrHappy said: Nice wiring.... That's the old system Quote Link to comment Share on other sites More sharing options...
Grego Posted September 26, 2023 Author Share Posted September 26, 2023 31 minutes ago, al-yeti said: Speaker wire? It's a photo of the old system. Which explains why it's being upgraded. But yes, I can see your point. Quote Link to comment Share on other sites More sharing options...
Grego Posted September 26, 2023 Author Share Posted September 26, 2023 48 minutes ago, MrHappy said: dunno, TBH I couldn't give a Castlemaine 4x Well, if you ever find yourself in a bar brawl with a kangaroo, at least you'll have a cold Castlemaine XXXX as a peace offering! Quote Link to comment Share on other sites More sharing options...
Grego Posted September 26, 2023 Author Share Posted September 26, 2023 I appreciate the professional installers on this forum, and I understand that my situation may seem less than ideal. I want to assure you that I am doing everything I can to improve the current circumstances. This situation is not intentional, and if there were a straightforward solution, I would have implemented it already. However, there are some challenges that will require time and effort to address. Your advice and guidance are valuable to me, and I truly appreciate your support. Thanks, Mark 1 Quote Link to comment Share on other sites More sharing options...
