Haveagoatanything Posted November 8, 2022 Author Share Posted November 8, 2022 This is the wiring from the old PIR that I have just rewired to as it was. I have just set the alarm and this zone triggers the alarm! So it did/does work. (Not sure about the other zones) 20 hours ago, Imnotshankled said: OK you have a texecom veritas r8 Looking at the wiring none of the zones are linked out and there's nothing wired to the SW out terminal which is good This most likely narrows the fault down th the pir the eol link on captures are a switch set it to OC OC which is the top option I will give this a try! thanks! Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 8, 2022 Share Posted November 8, 2022 Well the panel isn't capable of EOL so it should be O/C Link to comment Share on other sites More sharing options...
al-yeti Posted November 9, 2022 Share Posted November 9, 2022 On 08/11/2022 at 18:23, Haveagoatanything said: This is the wiring from the old PIR that I have just rewired to as it was. I have just set the alarm and this zone triggers the alarm! So it did/does work. (Not sure about the other zones) I will give this a try! thanks! Ok great so it will work when you sort the jumpers out as swb mentioned Link to comment Share on other sites More sharing options...
Imnotshankled Posted November 10, 2022 Share Posted November 10, 2022 OI i was the one who mentioned it first Link to comment Share on other sites More sharing options...
Haveagoatanything Posted November 13, 2022 Author Share Posted November 13, 2022 All the new PIRs are now installed and working, thanks you to everyone who contributed. I would of been lost without out you. thanks again james Link to comment Share on other sites More sharing options...
Help Posted December 23, 2022 Share Posted December 23, 2022 Hi, I am having a similar problem, what did you do to resolve? Thanks Link to comment Share on other sites More sharing options...
PeterJames Posted December 23, 2022 Share Posted December 23, 2022 2 minutes ago, Help said: Hi, I am having a similar problem, what did you do to resolve? Thanks In order to help it would be an idea to say exactly what is, or is not happening and what you did to cause it to happen or not happen. We are alarm engineers not mind readers Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted December 23, 2022 Share Posted December 23, 2022 It's all covered in the thread please read. Please start a new topic. Link to comment Share on other sites More sharing options...
