Swapping texecom AAA1000 PIR FOR Capture AKB-0001
This is the wiring from the old PIR that I have just rewired to as it was.
I have just set the alarm and this zone triggers the alarm!
So it did/does work. (Not sure about the other zones)
20 hours ago, Imnotshankled said:
OK you have a texecom veritas r8
Looking at the wiring  none of the zones are linked out and there's nothing wired to the SW out terminal  which is good
This most likely narrows the fault down th the pir   the eol link on captures are a switch  set it to OC OC which is the top option
I will give this a try!
thanks!
  • Replies 27
  • Views 39.7k
thanks!
Ok great so it will work when you sort the jumpers out as swb mentioned
All the new PIRs are now installed and working, thanks you to everyone who contributed.
I would of been lost without out you.
thanks again
james
  • 1 month later...
2 minutes ago, Help said:
Hi, I am having a similar problem, what did you do to resolve? Thanks
In order to help it would be an idea to say exactly what is, or is not happening and what you did to cause it to happen or not happen. We are alarm engineers not mind readers
