Swapping texecom AAA1000 PIR FOR Capture AKB-0001
  • Replies 27
  • Views 39k
No global tampers and it looks like a basic panel so only a bell tamper on the whole system
In the middle of a ring or radial when it should be on a 3a spur.
It's poorly installed so who knows what else will or won't work...
1 hour ago, Haveagoatanything said:
I took this yesterday when I had it open.
OK you have a texecom veritas r8
Looking at the wiring  none of the zones are linked out and there's nothing wired to the SW out terminal  which is good
This most likely narrows the fault down th the pir   the eol link on captures are a switch  set it to OC OC which is the top option
Edited by Imnotshankled
Never worked with companies on new builds eh
4 minutes ago, sixwheeledbeast said:
Seen plenty of poorly installed stuff from all types of origins... there will always be plenty more.
This is nothing compared to a premier shop I did recently  system was a texecom Premier elite 48
Psu was on a plug Top and panel was wired into a 40a cooker feed with no fcu or earth
Bell box had no battery in it
All detectors except front door were disabled
2 PA buttons never wired in
And Last but not least it had some crappy gsm SD
8 hours ago, Imnotshankled said:
This is nothing compared to ...
How do you know, I didn't expand, safe to say I have seen hundreds more systems in my time... I don't think it's relevant to play who can pee up the wall higher...
The OP wants their alarm repairing I have pointed out it's poorly installed. They can investigate why or get someone to fit it properly.
Here is the wiring on the P15, plus also the the G2 switch is on and the shutter at the bottom is set to dog. I haven’t moved the EOL setting.
