LMC Posted August 15, 2022 Share Posted August 15, 2022 Hi-I hope someone can answer my question as I am experiencing heath issues due to electrical interference (headaches, earache etc). I am unsure, but have my suspicions that the constant 'hum' I can hear is due to interference from neighbours' security systems, and/or wifi and have no idea what to do. 1)Is it possible that local security systems can affect electrics? I live in a link detached property with a neighbour to my side, one to the back, about 50ft away, and one across the road 50ft away, all with security systems. How far could their range be? 2)There are several wifis in the area, including a bt hotspot-is this an issue? 3)Is there anything I can do to combat this-there are plenty of companies selling 'dirty electricity blockers' that you plug in, but I don't know if these work or not. I wish to add that this is something I only experience in my home and garden (no where else), but I'm the only person in my house who can sense the 'hum'. I've been examined by doctors and they can find nothing wrong with my ears or my mental health, although it's been challenged! I've lived in the same house for 15 years, and spend 90% of my time in it. My symptoms have got worse in the last 3 years. If anyone can advise me, I'd be grateful! Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 15, 2022 Share Posted August 15, 2022 Id start by powering stuff down in your own house first and ensure it isnt something of yours. When there is a powerfail in the area does it stop? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 15, 2022 Share Posted August 15, 2022 My first thoughts are Tinnitus which could be triggered while being at home. It would be good to isolate your own electrics like above to see if it's something around your home. It's difficult to describe these sounds but the way you say "humming" makes me think of classic 50Hz transformer hum which would most likely be in your house if that's the case. The frequencies used by access points 2.4Ghz> and alarm systems 868Mhz are everywhere. It wouldn't make sense to have the symptoms be just at your home plus any of the shelf product would be EMC compliant. Do you even know if the neighbours security systems are wireless? If they are not then there would be no radiation from it. These dirty electric blockers you mention are most likely a placebo, best case they are an array of MOV's or capacitors to slightly filter a nearby mains supply, fine to clean up a sine wave but very unlikely to remove an "audible noise". Quote Link to comment Share on other sites More sharing options...
LMC Posted August 15, 2022 Author Share Posted August 15, 2022 Thanks for the suggestions. I've tried powering down items in the home (even the wifi) and it makes no difference to the effect on me. As for neighbours' security systems, I believe the house next door has a security system via wifi-don't think the others do. However, the guy who lived there died in May so I can't double check that. Excuse me for being quite so ignorant, but what uses a 50Hz transformer? Is there any point getting an expert in to measure EMF or buying a meter? Thanks x Quote Link to comment Share on other sites More sharing options...
Imnotshankled Posted August 15, 2022 Share Posted August 15, 2022 1 hour ago, LMC said: Thanks for the suggestions. I've tried powering down items in the home (even the wifi) and it makes no difference to the effect on me. As for neighbours' security systems, I believe the house next door has a security system via wifi-don't think the others do. However, the guy who lived there died in May so I can't double check that. Excuse me for being quite so ignorant, but what uses a 50Hz transformer? Is there any point getting an expert in to measure EMF or buying a meter? Thanks x I highly doubt its a alarm system the signals used are very weak It could possibly be due to cellular signals A transformer is used in hundreds of things from your mains powered doorbell to halogen lights I have a feeling its a cheap switch mode power supply as I used to have one that made quite a loud whine sound Quote Link to comment Share on other sites More sharing options...
LMC Posted August 15, 2022 Author Share Posted August 15, 2022 Thanks Logan-if it's cellular signals I assume its not harmful (i.e. radiation), although if I have a cheap switch mode power supply, could that be dangerous i.e. cause a fire? Sorry if I sound like a worry wart but because I have had health issues already because of this, I obviously don't want any more concerns for me or my family. Any suggestions how I could stop the headaches, earache etc other than having my electrics looked at? Ta x Quote Link to comment Share on other sites More sharing options...
Imnotshankled Posted August 15, 2022 Share Posted August 15, 2022 2 minutes ago, LMC said: Thanks Logan-if it's cellular signals I assume its not harmful (i.e. radiation), although if I have a cheap switch mode power supply, could that be dangerous i.e. cause a fire? Sorry if I sound like a worry wart but because I have had health issues already because of this, I obviously don't want any more concerns for me or my family. Any suggestions how I could stop the headaches, earache etc other than having my electrics looked at? Ta x It's not harmful As long as the switch mode PSU is not some suspicious Chinese supplier it should be fine however they will have another less EMF shielding compared to something like a samsung or apple psu Maybe it's my workshop to blame? Quote Link to comment Share on other sites More sharing options...
PeterJames Posted August 15, 2022 Share Posted August 15, 2022 I can hear the high frequency of some TV's , I can hear my fridge and my freezer, most of the time I just block it out. Ive never heard my router wifi or any wireless alarm devices. If they are installed by a proper company then they are most likely 2 way wireless which would mean they are not transmitting all the time they may pole every now and again and when the alarm they will signal when there is a burglar detected. The PSU will be switch mode rather than the old fashioned transformer so very little hum. 4 minutes ago, Imnotshankled said: It's not harmful As long as the switch mode PSU is not some suspicious Chinese supplier it should be fine however they will have another less EMF shielding compared to something like a samsung or apple psu Maybe it's my workshop to blame? Tidy! Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 15, 2022 Share Posted August 15, 2022 Regarding power, id knock off the whole house at the main switch to confirm its not a device in your house. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
LMC Posted August 15, 2022 Author Share Posted August 15, 2022 34 minutes ago, Imnotshankled said: It's not harmful As long as the switch mode PSU is not some suspicious Chinese supplier it should be fine however they will have another less EMF shielding compared to something like a samsung or apple psu Maybe it's my workshop to blame? Lol! x Quote Link to comment Share on other sites More sharing options...
