PeterJames Posted May 31, 2021 Share Posted May 31, 2021 What makes you think the fault is in the 4 inches that you cut off? Where does it run from to? By that, I mean does it run under the floor or around the skirting board, under the carpet etc? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511103 Share on other sites More sharing options...
norman Posted May 31, 2021 Share Posted May 31, 2021 1 hour ago, PeterJames said: What makes you think the fault is in the 4 inches that you cut off? Where does it run from to? By that, I mean does it run under the floor or around the skirting board, under the carpet etc? I read it as put on a fly lead. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511104 Share on other sites More sharing options...
PeterJames Posted May 31, 2021 Share Posted May 31, 2021 2 hours ago, Honda3 said: Ive cut 4 inches of the kepad wire and reconnected it. 26 minutes ago, norman said: I read it as put on a fly lead. It could be interpreted that way I suppose, but I read it that he removed 4" of cable off the keypad cable. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511107 Share on other sites More sharing options...
norman Posted June 1, 2021 Share Posted June 1, 2021 Yeah, 4' is a pretty short flylead. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511108 Share on other sites More sharing options...
Honda3 Posted June 13, 2021 Author Share Posted June 13, 2021 Hi thanks for the replies. I did that because the keypad was next to cellar door and it kept hitting it when opening, not ideal but was like that when i moved in. Its been ok since i cut wire but most of the time the fuse last months so not sure if thats fixed it. I Do realy want to replace the kepad because some buttons have become unresponsive. Any suggestions just for the keypad would be great thanks. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511212 Share on other sites More sharing options...
PeterJames Posted June 13, 2021 Share Posted June 13, 2021 you cant replace the keypad with another make/model you can only replace it with the same Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511215 Share on other sites More sharing options...
Honda3 Posted June 14, 2021 Author Share Posted June 14, 2021 K thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511225 Share on other sites More sharing options...
Honda3 Posted June 20, 2021 Author Share Posted June 20, 2021 It blew again!!. I realy want to change it over but think i should at least check with a multimeter 1st to try and find out why. Not 100% sure how though any suggestions would be great. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511321 Share on other sites More sharing options...
james.wilson Posted June 20, 2021 Share Posted June 20, 2021 You need to disconnect something or run it on its own fuse to diagnose which bit of kit is blowing the fuse securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511322 Share on other sites More sharing options...
MrHappy Posted June 20, 2021 Share Posted June 20, 2021 @Honda3 find a local tame alarm man, get them to price via email to replace the controls, battery & external bell. they'll measure all the cables & currents if they've 1/2 a brain... I'd assume your cables are stapled under the carpets ? Replace the fuse & tread on every inch of carpet where a cable might be lurking 1 Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44599-relace-adt-panel-and-keyboard-recommendations-please/page/2/#findComment-511323 Share on other sites More sharing options...
