Peter Reynolds
Hi,
I fitted an Abacus alarm in my home many years ago (DIYer) and have maintained it since, my problem now is the LCD keypad buttons make poor contact and I opened the cover causing (Keypad Tamper Trbl) My question is if I fit a new keypad are my  codes saved in the old keypad or the main alarm box or will the new keypad revert to the original default codes.
Many Thanks, Peter.
  • Replies 25
  • Views 6.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Good luck finding a replacement keypad they havent made those for 20 years
  • peterreynolds
    peterreynolds
    One is brand new in un-opened box, I sent the picture to them and they confirmed it is the same from old stock.
  • I'd bidding against him for giggles
Posted Images
Codes will be saved in the NVM in the main control, assuming batteries are all OK.
50 minutes ago, peterreynolds said:
Hi,
Many Thanks, Peter.
Battery is good, I've attached picture of the type of LCD Keypad just to be sure.
Codes are saved in the main control but just as a caveat it's not totally uncommon for older panels to corrupt or lose programming when down powered.
More than likely OK but worst case you would have to update/replace the control panel
13 minutes ago, peterreynolds said:
Thanks Norman and Peter J, there's a couple available on ebay.
Plenty about lol , but I would upgrade
Couple of used 20 year old keypads that wont be much better than the one you have. I know its easier to just replace the keypad, but I think you could end up exactly where you are now after you have replaced it, only a bit poorer
But an upgrade of panel and keypad is about £100? Even on basic like a 9651 with prox tags
