Risco wireless shock sensors tamper issue
Got a Gardtec 595 panel linked to the Risco wireless module. Two of the wireless shock sensors are triggering false tamper alarms and is now occurring at least twice a day.
Have tried changing the sensor battery but still the same.
Any othe ideas to fix?
Alternatively I could just get rid of them but I can’t figure out how to unconnected them from the wireless receiver, anyone know how this is done. I tried simply taking batteries out but that didn’t help
  • Replies 20
  • Views 11.1k
  • Created
  • Last Reply
Top Posters In This Topic
adjust spring (s) / the case is damaged
to remove from system you need to program the circuits off
Like all risco tat over time issues like this appear for no reason at all.I had this and had to replace them.
Had this issue with a wireless door contact last week randomly tampering and replaced it.
It is only in contacts that has been the tamper issue over time.
Well many systems got the querks , I got my first hkc wirreess contact  where the reed inside sticks  , but only one , Honeywell had loads in passed that send a low RF batt signal no matter what you do , texe always got firmware going so you know how it is
Risko have these problems long time now
The one way radio devices are rock solid
Gardtec controls are quirky, but workable
Wisdom / Agility, my life is too short...
As per previous comment, adjust the spring & ensure the battery is at a healthy level
some sit on a spacer,  so make sure that’s not causing any issues Or that the spring is not bent (has that before)
if you want to remove from the zone you need the engineer code & it’s done on the program zones (first option when in engineers mode)
Wisdom hardcore messed up , although I sold a few brand new boxed that someone gave up on
Does anyone rate risco anymore? I know the past and how it was 1 way would you use it out vs anything else?
Thanks all for comments. If I can’t fix them and get new senders I have the install manual for the senders that says set the  receiver to write mode but I don’t know how do this. The receiver is a separate square white box wired in to the gardtec panel.
if anyone has the install instructions for the receiver they can share that would be fab
Edited by MrHappy
removed Risco's file
