sixwheeledbeast Posted July 23, 2022 Share Posted July 23, 2022 That's why they use so much leccy... Quote Link to comment Share on other sites More sharing options...
Driller Posted July 23, 2022 Author Share Posted July 23, 2022 1 hour ago, sixwheeledbeast said: That's why they use so much leccy... Does SW sell lightning conductors? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted July 23, 2022 Share Posted July 23, 2022 4 hours ago, Driller said: There's a flux capacitor?! Agreed did you check the flux capacitor? Easy when you know how , or you need pictures? Quote Link to comment Share on other sites More sharing options...
Driller Posted July 23, 2022 Author Share Posted July 23, 2022 (edited) 10 minutes ago, al-yeti said: Agreed did you check the flux capacitor? Easy when you know how , or you need pictures? I would love to have a picture Edited July 23, 2022 by Driller Quote Link to comment Share on other sites More sharing options...
Driller Posted July 23, 2022 Author Share Posted July 23, 2022 Good God, it's true! Quote Link to comment Share on other sites More sharing options...
Driller Posted July 24, 2022 Author Share Posted July 24, 2022 Gentlemen, I now have a battery failure on that powered RIO module (of course) and only 9V on the board which makes sense. All the right lights are on (flashing red on RIO) fixed green on PSU (I removed the shroud). Can someone who knows please confirm that I need to replace the PSU module? Quote Link to comment Share on other sites More sharing options...
Driller Posted July 24, 2022 Author Share Posted July 24, 2022 21 minutes ago, Driller said: Gentlemen, I now have a battery failure on that powered RIO module (of course) and only 9V on the board which makes sense. All the right lights are on (flashing red on RIO) fixed green on PSU (I removed the shroud). Can someone who knows please confirm that I need to replace the PSU module? Ps forgot to say I have 220V measured coming into the PSU Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted July 24, 2022 Share Posted July 24, 2022 The SMPS will be likely be blown like above. You can't test more than in and out unless you open and they are not designed to be user serviceable. You could try power cycling everything and a new battery but most likely you need a new one. Quote Link to comment Share on other sites More sharing options...
Driller Posted July 24, 2022 Author Share Posted July 24, 2022 45 minutes ago, sixwheeledbeast said: The SMPS will be likely be blown like above. You can't test more than in and out unless you open and they are not designed to be user serviceable. You could try power cycling everything and a new battery but most likely you need a new one. Thanks SWB, so can I get hold of just the SMPS part or do I have to replace the whole thing? i was supposed to leave to go on holiday today, Sod’s law. Any way I could rig up a 12V 4Amp supply in the SMPS’s place temporarily? i guess the RS 485 bus would throw up an error if I did that. Quote Link to comment Share on other sites More sharing options...
Driller Posted August 4, 2022 Author Share Posted August 4, 2022 For anyone encountering a similar problem, got a new powered RIO but will just try swapping out the power supply part at first. Quote Link to comment Share on other sites More sharing options...
