Help please
Small bit further help. After getting the PIR sensor installed and working. I decided to do a walk test and see if everything was fine and which zones were which.
I believe these are shock sensors ? well i gave them a little nudge to see which zone they were in and now they flash red constantly. Anyone any ideas how to get them to stop flashing ???
I have set the alarm and unset it ive been into engineer mode and done a reset still they flash ALL NIGHT LONG !!
Any further help would be appreciated......
  • Replies 37
  • Views 72k
  • I once did a job in Ardrossan.....   I believe the foreign office, issue the same advice to travelers as they do for mogadishu, apart from the sun screen ?
  • Mogadishu is safer to travel to than ardossan
  • scotslad469
    scotslad469
    You would be required to wear a Haz mat suit at all times and that was before COVID-19   ??????????
Is there a reset switch on the panel? they need the power dropping off to reset the led iirc.
I can remove the battery backup and turn the power off to the panel. You think that would reset them ??
Personally I would only drop the power to the detectors.
I'm not sure with these panels but there will most probably be an output that resets on arm/set or something similar (pulse output perhaps?) that you can programme to drop the power momentarily on setting.
Worst case, you cold wire in a small unobtrusive switch to interrupt the 12v and mount it through the casing at the bottom or something.
1 hour ago, sixwheeledbeast said:
They flash red all the time with comfort on, latch line is solid light
They only started flashing when i tested they were working the other day.
Sometimes the comfort light can stop if they haven't been triggered in a while, pretty normal for Vipers.
Dude question
Does the alarm set and unset
If you tap the windows does it set the alarm off ? (Don't break glass) try screw driver tapping on frame then lightly on glass near them
You still fit many ? I hate them lol but then I am a house basher I guess....
Nope, use the Texecom Impaq ones unless I have to use proper Vipers for replacement (aesthetics/latch line etc)
Mostly wireless shocks now if customer needs perimeter.
Ah.
