Help please
I guess I could type it out but I am going to  be lazy , your just getting confused the word eol , ignore it , so then instructions are the same as what I said before
White and green to tamper terminals
Blue and yellow to alarm terminals
Black is minus - terminal
Red is positive + terminal
  • Replies 37
  • Views 56.8k
  • I once did a job in Ardrossan.....   I believe the foreign office, issue the same advice to travelers as they do for mogadishu, apart from the sun screen ?
  • Mogadishu is safer to travel to than ardossan
  • scotslad469
    scotslad469
    You would be required to wear a Haz mat suit at all times and that was before COVID-19   ??????????
Thanks for the help. I owe you a few of these ?????
Iron brew?
10 hours ago, al-yeti said:
Iron brew?
5 cups of cold piss ?
Thanks to all the replies.
PIR now working perfectly few issues I forgot I set the alarm to all the defaults so not knowing the default pin was #### i triggered the tamper and couldn’t shut it down but got it all done in the end.
Edited by sixwheeledbeast
no codes please
