May 21, 20206 yr comment_501520 I've got an old 808 with a fault that will not clear. The LCD star burst display reads: PAS B H or PA5 B H as it's a star burst display its difficult to read. Any ideas as all ccts are ok... It fails test on existing eng mode. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 21, 20206 yr comment_501522 Wow, an 808 on starburst Unfortunately I only ever used the starburst as an arming station. Do you have the eng manual though? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501522 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 21, 20206 yr comment_501548 2 hours ago, Wooly-bobs said: I've got an old 808 with a fault that will not clear. The LCD star burst display reads: PAS B H or PA5 B H as it's a star burst display its difficult to read. Any ideas as all ccts are ok... It fails test on existing eng mode. Scrrrrrrrrap Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501548 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 22, 20206 yr Author comment_501554 5 hours ago, datadiffusion said: Wow, an 808 on starburst Unfortunately I only ever used the starburst as an arming station. Do you have the eng manual though? Got the manual from the SRI disc but the starburst descriptors dont list this particular fault code... it's a wierd one.. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501554 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 22, 20206 yr comment_501555 Yeah sorry I didn't notice you were trade. I too checked the manual and like you say it's not in there! Do you deffo get the 'Cant exit faults = 1' type text when you try and exit, but before this, then? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501555 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 22, 20206 yr comment_501557 some sort of panic prob ? either a button on a circuit or something to do with key 1+3 ? check wiring, power cycle, default reprogram or rip it off the wall & stamp on it.... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501557 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 22, 20206 yr comment_501562 Yeah I'd have to say even as a scanny fan this is never a panel I've wanted to support. Actually I've only ever fitted an 816. Does the 808 only support starbrust then? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501562 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 22, 20206 yr Author comment_501587 I've never been a fan of this particular panel mainly because its mounted in a right awkward place that requires contortion skills to work on.. I've checked the wiring, nothing a miss, did power cycle the unit but still a fault. I did tell customer that a new unit wasnt out of the question, this thing is old, the clock memory fails on it after being set. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501587 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 22, 20206 yr comment_501588 i presume all parts of the starburst function? Its not that bits are missing? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501588 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 22, 20206 yr Author comment_501593 Display is ok James. I dont know why a proper keypad wasnt fitted on install. The original company was well known for corner cutting... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43836-scantronic-808/#findComment-501593 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
