Scantronic 808
I've got an old 808 with a fault that will not clear.
The LCD star burst display reads:
PAS B H
or
PA5 B H
as it's a star burst display its difficult to read.
Any ideas as all ccts are ok... It fails test on existing eng mode.
Wow, an 808 on starburst
Unfortunately I only ever used the starburst as an arming station.
Do you have the eng manual though?
PAS B H
or
PA5 B H
Scrrrrrrrrap
Got the manual from the SRI disc but the starburst descriptors dont list this particular fault code... it's a wierd one..
Yeah sorry I didn't notice you were trade.
I too checked the manual and like you say it's not in there!
Do you deffo get the 'Cant exit faults = 1' type text when you try and exit, but before this, then?
some sort of panic prob ?
either a button on a circuit or something to do with key 1+3 ?
check wiring, power cycle, default reprogram
or rip it off the wall & stamp on it....
Yeah I'd have to say even as a scanny fan this is never a panel I've wanted to support.
Actually I've only ever fitted an 816. Does the 808 only support starbrust then?
I've never been a fan of this particular panel mainly because its mounted in a right awkward place that requires contortion skills to work on..
I've checked the wiring, nothing a miss, did power cycle the unit but still a fault.
I did tell customer that a new unit wasnt out of the question, this thing is old, the clock memory fails on it after being set.
i presume all parts of the starburst function? Its not that bits are missing?
Display is ok James. I dont know why a proper keypad wasnt fitted on install. The original company was well known for corner cutting...
